Here is a really great tip that worked so well I kicked myself for not doing it sooner. On Hobies, you tie off lacing line using a bowline knot then lace line from grommet to grommet in a "Z" pattern, what I did was use a double loop on the horizontal leg and stayed with a single loop on the diagonal. (The top and bottom of the "Z" are the horizontal, the joining line is the diagonal). What happens is the tension on the 2nd loop locks down on the 1st loop maintaining tension, as you have found out, the difficulty is not in creating tension, but in maintaining that tension as you move to the next loop. This worked so well for me, (too well in fact), that I had to go back and release tension a bit as I had a mesh tramp and you run the risk of too much torque, pulling the grommets out of the mesh.
Wear gloves when doing the lacing, start with bowline knot on 1st grommet, loop through 2nd grommet from
top, instead of going down to 3rd grommet, loop back up through 1st grommet, down through 2nd grommet, down to 3rd grommet under tramp and up through 3rd grommet from underneath. Double loop between 3 & 4. Lace entire length of tramp loosely in this manner, the diagonal always under the tramp. Then go back to the 1st grommet and now crank on the tension between grommets 1 & 2, using the 2nd loop. 2nd loop locks down tension on 1st loop allowing you to move on to next double loop, repeat. You will have to maintain some tension in line between double loops but you will find that you will not suffer tension loss as with a single loop.
In effect, you're using 2:1 haul to create max tension, with the bonus that 2 lines through a single grommet have a lock-down effect. It worked so well for me that I used it to lace up the tramp on my P18 with most satisfying results.
Hope I explained this clearly,
hope this method helps.
TurboHobo
H14T
P18
P16
