The cam cleat on my traveler gave out. It worked fine one day, the next, it wouldn't cleat. I noticed that one cam would move all the way inwards, while the other hardly moved from centered.
My first thought was a spring had broken, cleaning & closer inspection revealed that the teeth have the sharp edges worn down.
I can make it sort of work by using really thick line,that gives some grip at the periphery, where the teeth are not so worn, but the line is to thick to tie off at the eyestrap.
I robbed the aluminum cam cleat off my Invitation, but the mounting holes are a slightly different size, & I can't mount it flush with the base. Same goes for the cleat on my righting bag, it is also aluminum, & harldy ever gets used, but it won't quite fit this Holt Allen base.
Can you buy just the cams, or do you have to fork out appx $40 + shipping ($30 from Murrays) & buy the entire unit?
