The mast step had about 1/4" of play in it from fore to aft. I could see the crossbar below was pretty worn so I decided to remove the step and see what I was dealing with. As you can see the cross bar is worn andout 1/32" into the top surface and the center hole is oblong.
Im replacing the entire dolphin striker assembly and Would like to repair the cross bar. I'm thinking of welding up the center hole and rivit holes and redrilling. I would also like to fill in the worn areas with weld and then grind smooth. Does any one know if the heat from welding will compromise the strength of the cross bar?
The other option is to drill the hole larger and use a stainless sleeve around the dolphin striker post.
