OK- I'm putting my 5.2 away for the winter after a great day sailing on lake Hartwell this past weekend. I have a couple of issues to address before the spring comes.
1. I broke the zipper mechanism off of my jib (the teeth are still in great shape) Is there a way to replace the zipper thingy (loss of a better word) without replacing the entire zipper or sail? I was trying to chase down a trimaran on Saturday but came up short due to passenger load (3 adults) and the absence of my jib- boo!
2. This is the first boat I have owned that has a main sheet traveler. I have experimented with adjustments, but am unfamiliar with its proper application (beating/running/reaching- light vs heavy wind). Help?
3. Are there times where one should adjust the downhaul? I usually set it and forget it.
4. The newer mast step for the 5.2 with the pin is wonderful! If you have the old design; get rid of it and replace it with the new. Much easier raising and lowering the mast.
Is there some place I can send my sails to be serviced - i.e. repaired, re-grommeted, cleaned, etc? They are still in good shape (extra crispy :)) and I can't justify replacing them yet.
Happy winter, all!
Eric C
Force 5 project boat
Unnamed
Previous boat
1980 Nacra 5.2
"Double Vision"
