Hi guys,
I'll split this from my other post, as it is a different subject really.
I've recently brought a Windrush 14 (mk1) that the seller was less than honest about the condition of, and am now trying to work through the best solution to get out in it without spending a huge amount of cash (at least for the time being).
There are a few things I need to sort out, which I will list below in the (my opinion) order of importance. I really want to get out soon, or it might never happen!
1. Mast rigging -
- Now I've had some advice on this, but am still a little unsure. Best to check below first first where I went into a bit more detail:
http://catsailor.net/forums/showthread.php?3683-Windrush-14-rigging
Based on what I've learnt there, it would seem I have the original rigging (which is fine, its in ok order) - but there are no chain plates/pins/turnbuckles etc - just the tweaker lines (which I'll try to get a pic of today - but basically two lines to the headstay cleated back to create tension). Which means that I couldn't do as suggested and get rid of the headstays - there'd be nothing to tension with.
Does this seem to be a sound mast rigging? I'll upgrade to some adjustable shrouds or similar at some point, but is this OK for now?
