Hey Everyone, I have been progressively upgrading my Nacra 5.2 over the last couple of years. I got an awesome flat top main sail last year but found that with only a 3:1 downhaul and straight spreaders I couldn't depower it. I rigged a 6:1 downhaul but it really didn't fit in the space left by my mast rotator and boom. None of the off the shelf systems will fit my boat either.
Well I acquired some backswept spreaders and have been trying to figure out how to make a high purchase downhaul that I could fit. I was searching the internet and stumbled across this!!: http://www.thebeachcats.c…ictures/?g2_itemId=78848
It is an absolutely perfect setup for a tight area and very simple. You can reuse the stock cheek block and strap eye and move the multi-pully system to the side of the mast out of the tight spot and easily get upwards of 28:1 purchase, I wouldn't recomend more than a 12:1 for an old 1981 boat like mine, but it should work SWEET. The only downside is you can only work the downhaul from one side of the boat. You could install a second setup on the other side of the mast to give you access, but for guys like me who sail for recreation only set and forget is fine.
This system would also work for an internal downhaul inside the mast, if you have a lot of patience and a bit of inginuity.
I have been looking for a long time and when I saw this I got so excited I had to share! :)
D.
Edited by Wolfman on Dec 25, 2010 - 10:11 PM.
