http://www.thebeachcats.c…f821d6aaf4acd8ceb5c6ac8f
here is some pics from my deck lid repair last spring, drill some holes in a pattern around the soft spots, don't drill through both layers of glass, just the top layer. drill holes same size as big syringe tip. mix up standard fiberglass resin, put it in syringe and fill holes til resin runs out surrounding holes. cut off excess resin from holes with a razor when resin starts to cure. mask off repair area first to keep unwanted resin off of surface...go sailing!!!
i'd be glad to help with more detailed info when/if your ready to do it. good luck!
Edited by coastrat on Jan 16, 2011 - 05:46 PM.
