Posted: Mar 21, 2011 - 11:17 PM
The 5.8 is a big nice boat. Typically sailed 2-3 handed. There are 2 versions the standard and the NA (North American). The NA has a (much) larger jib like a Hobie 18.
5.8m is 19ft. That's 3ft longer than a H16 (the sudo standard for cats), but heavier. The hulls are all fiberglass (read DIY repairs are easier) and there is many parts available the this site and ebay.
The mast is 30 or 31 ft long so it's non-trivial to step. If you can leave it up most of the time on a beach, then that is not an issue.
Take a look at the foil on the front of the boat, between the hulls attached to the fore-stay. Make sure its in good shape as Nacra is not really making this part any more and you will have to manufacture a solution should this break. A fellow sailor on our beach has this very issue right now. Murrary's is little help on this.
If it's in good shape, you have crew, like to trapeze and you know how to sail, go for it. If you will try to sail/rig alone you might look for a smaller boat.
If you do get it, understand this is a big powerful boat. only go out in under 15kts of wind your first couple of times as she will go like a bat out of hell, but that's kinda the point.
Once you get comfy, this is a great boat for those 20-25kts days that we long for.
Edited by nhanson on Mar 21, 2011 - 09:21 PM.
nacra inter-18
CNBP
