Hello to you all. I have been lurking here for some time now and wanted to say thanks for all of the wonderful information I have gathered thus far.
I just bit the bullet and purchased an '83 Hobie 16 and am extremely excited. It needs a lot of work and I could certainly use any advice offered. I have sailed in the past but its been well over a decade now and I am essentially starting from scratch. I will be sailing initially in fresh water, but after getting the hang of it again I am anxious to take her to the ocean!
To start with a couple of my big concerns (I have taken lots of pictures of each and every individual piece that i have along with it. I would like to document my entire progress for a little added fun.)
Hulls- One soft spot in each hull. just to the front of the frame. They are about 1'6" long and 8" wide. Seems like someone was continually stepping there to get on and off the boat. I found these instructions and it seems very doable-http://www.hobiecat.com/support/articles/archive/?src=http://2010.archive.hobiecat.com/support/tech/delam.html
Also on the hulls are a few dings a couple which have gone through the fiberglass- the foam inside still seems fine but I would love to know what you all think is the best way to fill these and waterproof them.
The tramp is the original vinyl tramp. Although it is not torn (except for one eyelet torn out) It seems to me that it is close to being dry rotted. I may be wrong though as it still has flex to it without cracking. Is it possible to save the tramp if it dried out but not torn? If not I came across another post here about making a new tramp. I can get the tramp mesh material and use the original as a template. A friend's wife is a professional seamstress so i think it may be a doable process.
My last big question (and I am sorry this post is so long)
I was wondering if anyone had an easy to read parts list for all the hardware. I know all the pulleys are there but I am missing almost all of the pins and connecting pieces (I know I nailed those technical terms right?)
I am thinking of ordering my lines from these guys as it seems to be the best value for the package that I have found-http://www.saltydogmarine.com/product_info.php?cPath=421&products_id=674
Anyone have any experience with them?
Also has anyone found a package deal on all the necessary hardware such as above? i wouldnt mind having some extra pieces as spares if I already have a piece.
Sorry again for the long post and thank you all,
Jon
