Nacra 6.0NA rigging
Does anyone have an pictures or drawings of the barber hauler and mast rotation setup on the Nacra 6.0NA they can share? I have the Nacra manual, but the pictures are really bad. Thanks for any info.
Post some pictures of what you have and I will help you. Setups are different so I need to see what you have.
I believe it is almost he same as a 5.7, check out ECs photos here:
http://www.thebeachcats.c…ictures/?g2_itemId=71715 they may help you with the rotation control.
Barberhauler should be similar to mine here:
http://www.thebeachcats.c…ictures/?g2_itemId=74145
Although Nacra had a couple of variations on that system.
My main beam fittings match the photos by Wolfman, but beyond that, all rigging for the barber haulers and rotation was removed by the PO. I guess that leave me a clean slate! Mostly I am looking for ideas on how it was done in the past before I reinvent the wheel.
Wolfman
Thanks for the pics, these help a lot!
