Mounting a boarding ladder
Hi Everyone,
As you may or may not know last year I had a pretty bad experience with my 5.2. My wife and myself were out if fairly heavy winds and she fell off the boat. She couldn't get back on the boat and I couldn't lift her back on (she is short and heavy with very little upper body strength, but don't tell her I said that). Fortunately someone came and got her so I could get the boat back.
Subsequently I purchased a plastic/rope ladder and tried to use that to reboard. No dice, putting weight on the ladder causes it to go under the boat and you to fall back, you need something to push against. Then I rigged a rope stirrup off of the rear beam and was able to get her back on by having her put a foot into the stirrup, grabbing her PFD and heaving like crazy. It is still a problem and I'm not only worried about sailing with her but anyone else of similar proportions who I may take out.
Anyway It's getting close to the start of the season and I haven't yet figured out a really workable solution.
I was thinking of mounting a telescoping ladder under the front beam such as this one: http://www.westmarine.com…Num=10397&classNum=10398 it should be fairly simple to mount and stow.
The other option I have lookd at is attacheing a strirrup between the front beam and the forestay adjuster, although I'm not overly enthusiastic about the stress that would put on the rigging.
The last option would be to hook a 4:1 purchase adjustment system to one of the trap lines with an extra long leader line, attach it to a PFD or harness and haul ass (literally).
Any I'm looking for opinions, options and experiences.
Regards,
i have found that getting back on a cat via the trap wires is easiest (for me at least)
i have 2:1 adjustable traps. seems like a 4:1 could do the job but attaching it to a pdf doesnt sound good or comfortable to me. i would think it would choke her or hurt her
Yeah, I would probably make her wear a trap harness to try that trick (if I can convice her to wear it). Or fabricate an under the shoulder harness out of an old 1960s style waist float (yes I have a few of them kicking around).
The new wings may actually help the situation because they will provide something solid to grab onto and something to hang a stirup off of.
As an extension to your first idea, here is an interesting transom ladder:
http://www.garelick.com/product.php?pnumber=19700
It is designed to telescope into a transom which works great on say a bass boat. While transom mounting is not really possible on most cats, the ladder could be mounted on the underside of the front or rear cross beam using custom fabricated plate or bracket. When the ladder is closed it would be out of the way under the tramp. It seems pretty compact and unobtrusive. Garelick has a pretty good collection of other ladders too.
Edited by DaveW70 on May 05, 2011 - 11:57 AM.
Dave Wilson
Hobie 16, Hobie 14
Tampa, FL
I had a similar situation in Cape San Blas while on vacation last summer. I pitchpoled the boat with sister-in-law and young niece. The niece was easy to get back on board but the sister-in-law had a similar problem. The niece started screaming bloody murder when we fell in and did not stop until she was back on the beach. I never could get the sister-in-law back on the boat and she swam back to the beach with some folks that swam out to help/investigate wheteher we were beating the niece. We were not she was just scared. I'm not sure if my girlfirend could get back on the boat in water over her head but I could probably lift her onto the boat. I'm sure it was a pretty funny situation to watch getting the sister-in-law back onto the boat. I tired to use my shouler to lift her onto the boat from the water and only succeded in flipping her over the port hull. Post some pics of what you come up with.
Griff
Tuscaloosa, Alabama
Not so funny in my case. Anyways, on a 16 or a 17 if you go right up near the bow you can pull the boat down enough that it makes it easier to get on. I could once. Maybe not today. A Wave is a long way up and has lots of flotation. There was a thread, with a proposed solution, on the Catsailer Magazine forum.
http://www.catsailor.com/forums/ubbthreads.php?ubb=showflat&Number=149070#Post149070
Let us know. Still too damn cold for me to try.
I am a big guy and have the same problem getting back on the boat. I have done one time with the help of my oldest son and it was very difficult. My wife went over on a friends boat and had a difficult time getting back on as well.
I have been trying to come up with a solution a well. The side of the boat by the shrouds just does not work for me I have to much weight pulling outward and not enough leverage to pull on board so as I go up I go out not in. I think the best bet for me going to be something at the beam between the hulls. I have had 2 ideas I have been thinking about. One is a retractable rope like the righting lines that have a hollow rope with a bungee core. On end starting at the beam the other traveling forward to a bit behind where the bridle connect (This is on a P18) I would connect these by putting a hole in the lip of the deck lid similar to the ones used for the shrouds and bridles and feeding it though and tying it off. The bungee would retract this along the underside of the deck lip and the rope would allow it to be pulled down just a bit to get a foot hold. I also considered at piece of PVC or some thing in the middle to act as a step. At this location you have both the beam and the hull to work with. If you can throw a leg over the hull you should be good :) right. You could have one on each side.
Another idea was a variation only it would stretch between the hulls just in front of the beam. I haven't been able to work out the logistics but picture a kind of rope ladder that is attached to the inside of both hulls. When not in use it is stretched tight via bungee across both hulls kinda like the tramp. When need your weight can pull is down under the water letting you get on top of it. The rope parts would restrict how far in the water is could go so you could actually sit on it and be just a foot or so under the water. You could use the ladder rungs to climb towards either hull until you could sit on the beam. By being attached between the hull the rope ladder could not be pushed under the boat making it impossible to use.
I have has no time to make a prototype of either.
Also one other idea was a straight rope ladder attached to the front beam in some sort of bag that zipped it in. You can unzip then attach the bottom end via carbiner to something on the front of the boat like where the bridles attach and or the bottom of g the forestay. This would keep form going under the boat but it would be difficult to put it away until you got to the beach.
Sorry for the typos I dont have time to proof read.
Oh and I like both those ladders but I have no idea how you would implement them.
Edited by Quarath on May 05, 2011 - 03:53 PM.
Also just found this
http://www.westmarine.com…Num=10552&classNum=10553
they also have a 5:1 version
Yeah, I saw that thread. Thinking of doing somthing similar to what Quarath suggests and similar to the thread. Using a couple fo blind stainless anchors (snap toggles) I was going to mount a couple of eyestraps in front of the front beam on each hull. Then I would run a line between them that could act as a step while you board over the front beam.
I'm really starting to like the idea of the West Marine ladder though The undermount brackets are small enough to mount under the front beam using some spacers. The ladder itself could then slide out forward while you board and be slid back under the tramp for storage. The other option would be to mount it under the back beam (if there isn't enough room between the dolphin striker strap and the front beam). In that case you would have to detatch the tiller arm between the rudders to board. Not a problem on mine because I have quick release pins for them but might not be an option for other boats. Also the tendancy for the boat to head down wind when trying to board from the back is an issue. I will see what I can come up with.
Definitely let me know what you come up with if you can work out the details of any of those ideas. keep a list of materials and lengths and pictures.
I used to do long distance barefoot waterski racing and we would have to pull teammates from the water into the boat to expedite turnaround between skiers. We found that if you are trying to pull the person into the boat with them facing you, it took alot more effort to pull them in than when they are facing away from you. I haven't had to try this technique on the sailboat but it should work. Grab her by the vest at the top of the shoulders and yank.
I have a similar concern for my wife due to her similar morphology as Wolfman's. My wife has a hard time getting into the boat wihen it is floating in 2 feet of water.
It's not perfect, but you can use the mainsheet. We used to sail with a big guy "Smitty" he did not have the upper body strength to get himself on board, and I don't think Gov Arnold S could have lifted him in his prime. After a capsize his crew said he had taken the mainsheet off, attached it to the trapese & trap harness and lifted him up, 8:1 & 400 pounds is a possibility.
Quick release shackles, and a roller furler for the jib make doing this easier.
Hope this helps
Steve Fisherkeller
P19MX
I actually am considering that. I have a set of 6:1 bullet blocks with a cleat that I was going to use as a downhaul that I may push into service. My Main blocks are quick release already but I really don't want to detatch them while sailing.
D.
Dave, what about attaching a telescoping ladder, or whatever to the front beam. As you note the problem is the ladder wants to swing under the boat.
However, this is easily prevented by having two short lines, (one attached at each bottom corner of the ladder) with a snap hook at one end.
To use it, drop the ladder, then attach a line to the loop where the bridle wire attaches to the hull, one line to each hull. Make the line just long enough so that the ladder can hang nearly vertical, but won't be able to swing under the boat.
Using two lines will prevent the ladder from twisting, & length will determine how far past vertical the ladder can swing. The lines go out at an angle, leaving free access to the ladder.
It would only take seconds to clip the lines on, & as long as the person has enough leg strength to climb 3-4 stairs it will work. I don't have a photo, but I built such a system decades ago to access a treehouse. We only had a short piece of wooden ladder & needed to stabilize the bottom. With the ladder swinging from a large branch, we had the same problem you do. The guys could manage, but Family rules dictated that the girls also got to use the pad, so that's what we came up with.
EC,
Take a look at the link above, The one I am thinking of is the undermounted one. It works similarly to what you are describing. I would mount it under one of th beams and it would sit unde r the tramp when not in use (with the telescoping rungs sticking a little bit out front) and when needed you pull it out and pivot it down. When finished you pull it back up and push it in. I'm thinking of attaching shock cord to the top bars to make it semi self retracting.
Anyway the ladder is on order, I will let you know if it works out and post photos. If it doesn't I will mount it to my dock.
D.
I actually looked at that ladder in a West marine store the other day and I don't think it mounts the way you are saying it does. The pictures on the pack show the 2 brackets mounting to the top of a deck then the ladder lays flat on the when collapsed but to use you swing up out and down then it is supported by the brackets and ready to use. It did not look like it would work the way you are suggesting.
I like the idea of a little extra lift action perhaps a sling step like
http://www.westmarine.com…Id=24220&catalogId=10001
combined with a 5:1 pully system. You could rig it off the front of teh mast and when not being use pull the system tight along the mast. You might have to install a separate mast hound on the front of the mast to hook it to.
Quarath
That looks like the ticket, that type lift could be lowered deep enough into the water that anyone could get their foot on it, then pulling it up like an elevator combined with crawling in across the front beam should work. And it's easy to stow. If you don't want to attach an additional mast hound you could run a 1x19 shroud type wire up along the mast to the existing hound down to a point where your ladder blocks would attach.
I think you are lookingat the over platform version. (2 top photos) Where I cam looking at the undermounted version. I will let you know anyway, it's already in transit.
D.
WolfmanI think you are lookingat the over platform version. (2 top photos) Where I cam looking at the undermounted version. I will let you know anyway, it's already in transit.
D.
You are correct that is the one I saw. The under mount though still looks like it would extend down into the water and create drag even collapsed.
damonAdmin
Quarath
I might need to rig so I can use it to make it easier to get on the hulls for righting to. I can do it but not without more than few bruises and a whole lot of spent energy. If I slip off I worry I won't have the energy for another shot.
My wife has trouble getting on the boat from the water, and I expect it can be hard when you are tired, cold, or wornout. A bunch of folks had goood ideas for assisting someone onboard. I rigged a rope step that is bungeed to pull up on the tramp. You can grab it with your hand, pull it down and put your foot in it, and step up on it as you scramble aboard. The rope has a stopper knot and bottle cap to set it's pull out length through a grommet in the tramp.
I made a photo album in:
Albums / Beachcats Technical / Rope Handle-Step
http://www.thebeachcats.c…ictures/?g2_itemId=82796
John Fricker
Prindle 16
Seabrook, Texas
jfricker, that's clever!
I just remembered my trick to get aboard was to go aft and climb on the sterns which were easier to submerge. I just pushed the crossbar hard over so I wasn't climbing over the tiller arms, or else just climb over them. Keep in mind I was sailing on a NACRA 18 Square, by myself, so I first had to make sure the main was uncleated or I might be steering the boat somewhere I didn't want to, ha ha
Edited by tami on Oct 21, 2011 - 08:25 AM.
Uhm, very weird suggestion, but isn't it possible to use the righting line to climb back aboard? all of ours are tied off just aft off the mast on the tramp, if you could possibly tie it of somewhere else (shroud, tramp).
Stefan, Denmark.
H14,H16,P16,P18,SC17,N5.8
Team StaySail
http://www.staysail.eu
John, you need to work for the rocket ranch. They need folks like you! Of course you would be worried about your job about now so, never mind.
A couple of questions; what size elbow is that, (looks like 1/2" but I could be wrong)? Also where do you tie off to at the stern?
When you swing up, can you grab the trap wire handle to help haul yourself out of the water? Looks like you can but hard to say from the pic.
Thanks for the idea, I am doing some rigging replacement on my 16 and this will definitely be on the list.
Mike Brady
Sugar Land, TX
P16 "Pooh Cat"
Quoteisn't it possible to use the righting line to climb back aboard?
Yes. I considered tying a step to the righting line, but didn't like how bulky it became and also did not want to have to have someone onboard deploy the righting line and then restow it. There is one step on each side, so they can get aboard on either side by themselves.
Quotewhat size elbow is that, (looks like 1/2" but I could be wrong)? Also where do you tie off to at the stern?
I think it is 1/2" PVC. I used 3/16" rope which is a bit thin and might switch to 1/4". I tied the bungee to the tramp lacing in the back corners.
QuoteWhen you swing up, can you grab the trap wire handle to help haul yourself out of the water?
I have not tried it in the water yet. I figure at that location you can grab the shroud, trap handle, front beam, and hiking strap so something will be available.
John Fricker
Prindle 16
Seabrook, Texas
Quoteisn't it possible to use the righting line to climb back aboard? all of ours are tied off just aft off the mast on the tramp, if you could possibly tie it of somewhere else (shroud, tramp).
My righting line is tied right behind the mast. I had a Hobie 16 years ago with the continuous righting line that ran around the outside of the tramp, and you could add a step to that setup which would be clean and accessible.
John Fricker
Prindle 16
Seabrook, Texas
You should be able to. I can easily reach the handles from in the water. My method for boarding is to swim alongside, reach up & grab trap handle, then swing one leg up onto deck. With both hands on the trap handle pulling, & one leg that gives some assist, I can flip back onto the deck within a couple of seconds. You sort of do a roll as you come up.
That is a great idea you came up with, simple, cheap, & most of all effective. Some people may not have the strength to push up using only one leg. Your system could easily be modified with either a wider step, or two singles, so as to allow both feet purchase. Anyone who can rise from a knee bend using both feet should be able to board unassisted.
jfrickerMy wife has trouble getting on the boat from the water, and I expect it can be hard when you are tired, cold, or wornout. A bunch of folks had goood ideas for assisting someone onboard. I rigged a rope step that is bungeed to pull up on the tramp. You can grab it with your hand, pull it down and put your foot in it, and step up on it as you scramble aboard. The rope has a stopper knot and bottle cap to set it's pull out length through a grommet in the tramp.
I like what you have done I think I will use a modified version to assist me. I have a step but from the water it is still not working for my fat ass. Your step as a retractable handle to pull on in the right spot(s) might help give me enough leverage to get up. I can do it with the step and a hand up from someone on the boat but not alone.
Also I cannot board from the sides too much center of gravity issues getting over the edge. It has to be front beam on a corner between hull and beam where I can get a lend on the hull in front of the beam.
I think when you try it from the water you might find this easier as well. I love the retractable idea well though out and nice and clean.
