Practice is good. Make sure the mast is sealed. Have a righting line rigged every time you sail. If you practice in shallow water make sure that there is enough room under the boat as it comes back up that you are not caught between the boat and the bottom. When the boat goes over get off the high hull quickly, this will help stop the boat from going turtle. Don't let go of the boat, it can drift away faster than you can swim. The boat will usually blow around till the mast is up wind. If you are in the water the drag of your body can help or hinder the boat swinging around. Make sure the main and jib sheets are released, you don't want the boat sailing off with out you when it rights. Now you are ready to try this
http://www.utahsailing.co…ghting-by-rick-white.pdf The wind that blew you over now helps right the boat. We capsized on purpose on a light wind day and had to exert more effort to get the boat back up.
Righting systems.
http://www.murrays.com/mm…_Code=C-RI&Store_Code=MSEdited by skarr1 on May 11, 2011 - 09:13 PM.
