Don't have a photo handy. You need about 6 ft of shock cord (any diameter will do). Connect it to the front beam near one hull (dolphinstriker is usually convenient). It goes up to the mast, though one diamond wire fromt the stern across the front of the mast and back through the other diamond wire and down to the front beam near the hull. If you have an aftermarket righting system they usually have a couple of places where you can conveniently attach the shock cord near the hulls.
http://www.thebeachcats.c…pictures&g2_itemId=35332 Here's a pic from the Nacra manual showing it. Should be similar for your boat also.
Also one from another 5.2
http://www.radesignz.com/…ing/08/redo/IMG_2582.jpg
D.
Edited by Wolfman on May 29, 2011 - 10:36 PM.
