gertsonf, glad to see you decided to revive your Prindle 18, I don't know if you got my PM encouraging you to look into fixing delamination. Here are the dimensions on the P18 jib"-
Leading Edge (Luff) - 16' 10"
Trailing Edge (Leech) -15' 11"
Bottom Edge (Foot) - 5' 11"
If the dimensions of the jib off of the Gulfport 18 are close, go ahead and use it for the time being, but try get a used P18 jib when you can, talk to Pete Begle here on this website
The forestay of the P18 is made up of 2 parts, upper forestay & lower forestay, the upper forestay is made up of a short length and a longer piece. The longer piece of the upper forestay has a ring attached, the shorter piece acts as a block. The longer piece of the upper forestay is connected to the lower forestay using a shackle, the entire forestay length measures in at about 246 inches.
The jib halyard runs through the thimble on the shorter piece of the upper forestay and through the SS ring on the longer piece, make sure both lenghts of the jib halyard run through the ring, also make sure when connecting the upper forestay to the mast hound that the shorter piece is closest to the mast. Once the mast is stepped and secured, attach the jib to the jib halyard using the small SS hook which should be on the one end of the jib halyard, in the shape of an "S", one end closed, the open end has a small loop on the outside edge
the halyard line connects to the small loop on the outside edge of the "S", connect the jib to the closed end of the "S" using a shackle, make sure the open end of the "S" hook faces the mast. Before you raise the jib by hauling on jib halyard, secure zipper around forestay and as you raise the sail, close the zipper, wait for hook to pass through SS ring on upper forestay, then pull down on the jib tack try to "engage" hook into SS ring, might take a few attempts of alternating pulling on the jib halyard and pulling on the sail tack untill hook catches ring. Now you can feed jib downhaul line through bridle shackle and take up slack, cleat line off at cleat on jib tack.
All of this info can be found in the Prindle manual, pages 21 & 22,
http://www.thebeachcats.c…ictures/?g2_itemId=75669 It's all too complicated for me so I converted to a furling jib, once I step the mast the jib is ready to go.
Hope this helps
Turbo
P18
TurboHobo
H14T
P18
P16
