I need to paint the starboard hull of my P-18. Do not want to go through the trouble of spraying gelcoat. Gelcoat is in poor shape and only worse after I drilled multiple holes in it to correct a delamination problem. The area to be painted is the entire hull. I have primed the hull with Interlux InterProtect 200E and plan to put on at least three coats. The boat will not be kept in the water (storing on land when not in use). I have tried to get information from staff at West Marine but they have different opinions: 1) Must use ablative paint for whole hull, 2) Use ablative paint below the waterline and topside paint above the waterline (this was despite multiple attempts to inform him that the waterline varies depending on crew weight, point of sail, etc. and 3) Can use a "topside" paint as the boat will not be kept in the water. Someone on this site has used a topside Pettit EasyEpoxy. Any experience with this or any other suggestions would be greatly appreciated. Thanks, Scott
ARC 21
Prindle 18
Annapolis, Maryland
