Almost got the boat in the water for this season, finally! The last thing I am working on is the new ring lock I have installed with a new top casting on the mast and hook tang. Everything I have read indicates that you should run the halyard over the sheave at the top of the mast and down the mast track. I am very worried that the halyard will not fit in the track, and that I will have trouble raising the main because I don't have a block at the bottom of the mast to act as a turning point.
Had anyone had this problem? Has anyone run the halyard outside the mast track? And if so how did you do it without abrading the halyard on the hook tang?
Regards,
