Well everybody I have a lead on a very cheap prindle 16. There is some delamination on one of the hulls and the decks are soft infront of the tramp. Read below and let me know your feelings about this expanding foam? I will not be racing, I will be just sailing for fun in the ocean here in daytona!
Foam comes in 2, 1 gal cont.( foam & harderner) and will fill 1 hull from tip to front pylon, I used 2 sets. Adds 16lbs to each hull ( 4cu ft x 4lb). You may want to go with the 2 lb. The 4 lb is a lot harder that the manufacturer describes. I believe the 2lb is going to be very hard also and you only add 8 lbs of weight to each hull. Up to you... if I was going to do over I would use the 2lb. Just to give you an idea of how hard 4 lb is, you cannot push a screwdriver through the foam, have to hit it with a hammer. Good luck...
This guy had this done for 4 years. Yea it added about 20lbs of weight but like I said I am not racing. This is marine foam used by boston whaler and will not absorb water.
What do you all think?
