That is a pivot block with cam cleat. You can get them at pretty much any sail shop. Here is one at Murray's marine on-line.
http://www.murrays.com/mm…_Code=C-BL&Store_Code=MS. Just so you know that is not a stock downhaul setup for a 5.0. Usually it is either rigged with a single block and becket with a v-jam cleat near where that pivot block is or use a fiddle block to give 4:1 purchase. YOu could rig it the same as in the picture and use a cheaper v-jam block on the mast. With only 4:1 the amount of downhaul you can apply on the fly will be pretty limited so being able to adjust it on the tramp isn't critical.
