Hello,
i have a question about the mast and stepping the mast. firstly, i find stepping extremely difficult, even with help and i am relatively strong . the mast refuses to remain on its pivot point, popping out half way up and causing me a whole lot of grief. is there supposed to be a pin that holds the mast in place while stepping, or does anyone have any advice / techniques to step the mast?
secondly, the mast does not rotate well once in position. it appears to have a lot of friction between the mast and its holder. should there be some sort of spacer or lubricant to help this?
thanks so much
