aaargh! try this for the 3rd time....the forestay on the P16/P18 is made up of 2 parts, the lower forestay with it's turnbuckle
and the upper forestay consisting of 2 parts
connect the longer length of the upper forestay to the lower forestay using a shackle
at the thimbles, leaving the SS ring to hang free.
Now connect the upper forestay to the mast at the hound using a large bell shackle, the sidestays on either side of the forestay and then your trap wires outside of the sidestays,
make sure the SS ring faces the mast. Before you step the mast, feed your jib halyard up through the SS ring, through the thimble on the shorter length of the upper forestay and back down through the SS ring, that shorter piece of the upper forestay is used as a "block" to raise the Jib. Be aware that both the shorter piece of the upper forestay and the SS ring must face the mast.
Now step the mast
The jib halyard is low stretch line with an "S" hook on one end
the halyard line is attached to the circle on the outside edge of the "S", attach 3/16 shackle to bottom of "S" hook and clamp loop on "S" closed, now attach jib halyard to grommet at the head of the jib, once again
make sure the hook opening faces the mast.
Now wrap the zipper pocket around the forestay and connect zipper, as you haul on jib halyard hold zipper tab and close zipper as jib is hoisted untill "S" hook passes through ring, gently pull on jib tack untill "S" hooks into ring, might take a few attempts b4 it hooks.
click on images to enlarge.
on the bottom edge of the jib should be a downhaul line attached to a grommet, thread line through shackle and up to cleat on jib tack. It's all in the P16?P18 manual
TurboHobo
H14T
P18
P16
