http://www.thebeachcats.c…ictures/?g2_itemId=62068
To stabilize the mast you have 2 side stays, 1 forestay, the forestay on the P16/18 has a turnbuckle and yes, the jib is attached to the forestay using the zipper pocket method. All shrouds/stays connect to the mast at the mast hound (also called mast tang), using a bell shackle. If your P16 has trap wires, these will also be connected to the mast hound on the same shackle, if you only have 5 "cables" then you have single trap setup.
read this post.
http://www.thebeachcats.c…ms/viewtopic/topic/12634
TurboHobo
H14T
P18
P16
