Hobie 18
I m new to sailing and buying a hobie 18. The hulls are solid and the boat overall looks ok. What are the typical problem areas to look for when making the final decision? Are there areas that are prone to problems? Help! thanks :)
IMHO: an H18 is an excellent, fun-to-sale, robust, and reliable boat. There are a few precautions I have found after going through this the last 18 months on a new-to-me boat. Here is my overly simple list of priorities:
Hull: Check for limited or no soft spots, especially near or in front of the front cross-bar. These can be a big headache (but usually not the end of the world). Abrasions and dings are generally easily repaired.
Crossbar reinforcements: Front reinforcement bracket is a must for heavy seas = ocean or great lakes equivalent or strong sailing. Rear reinforcement recommended for heavy seas. Cost to do this averages about $100 per cross-member plus a few hours of labor.
Side-stay anchor bolts: check for anything unusual (cracks, looseness, etc.) and be sure there are hull anchor brackets installed.
Sails: No tears, rips, chafed, or UV degraded spots. Major issues here generally result in sail replacement or restitching.
Rudder Mounting: Gudgeons should be firmly mounted to transom (no looseness or cracks in the fiberglass).
Shrouds and sheets: should be replaced at the first signs of abrasion/wear.
I'm sure others with more wisdom than I will chime in.
Jeff R
'88 H18 "Jolly Mon"
'10 C2 USA1193
NE IN / SE MI
cramsailing.com
http://www.thebeachcats.c…ms/viewtopic/topic/12598
Read previous posts on this topic very carefully
Turbo
TurboHobo
H14T
P18
P16
