The other day we did a 30 mile reach down the lake. Winds I think, were around 20 mph, solid whitecaps, but as the breeze was offshore waves were only around 1 ft, with the odd 2 footer.
I had my wife (125lb) & buddy (175 lb) on the wire, while I sat bracing a foot against the traveler casting. Occaisionaly we had a hull fully airborne, but mostly the windward hull was just skimming. We were fully powered & really flying, top speed hit 21 mph. I had the main cleated, & other than a few steering inputs to control gusts we drove it hard in this configuration for 15 gps miles.
About 1/2 way I heard a definite "creak", you know, the kind you hear when a line gets pulled to near break point. I chalked it up to transient strains, & as everything seemed fine we kept the speed up. I changed course slightly to clear the reef at the end of my bay & headed for home, still at full power. It was the fastest I've ever seen this 5.7 move. I heard another of the same "creaks", & they were different than the normal sounds this boat makes.
Upon placing the boat on the lift, I noticed the DS rod at a different angle. It did not bend, but appears the entire front beam rotated, (mast ball went towards the bows) The curved block that bolts inside the beam is 1/4" off the tramp track now, that had to be the noises i heard.
I had all straps at the spec 18 ft lbs, don't know what the internal beam bolts were. I have driven the 5.7 in much rougher water, at times so rough we had trouble staying on the boat, or keeping it upright. This was the most consistent wind I have ever seen, no real gust loads, & fairly flat water. The only thing I can think of was not enough tension in the shrouds, & that allowed the mast to move forward under load, transfer load to DS ball, & rotate the entire beam.
Any thoughts, ideas, recommendations? I'd hate to think that I can't pull that much power, cause man, what a ride!
