Took out my new old 1976 P16 over the weekend with a heavy load (4 adults) and after 4 hours of sailing I had alot of water in the right starboard hull. Took several minutes to drain. I have noticed a small drilled hole under the rear hull plug beneath the rear cross beam is this a weap hole or is this not supposed to be there as the other side does not have one. The O ring is good on the drain plug. What are the most common areas to check for leaks? Please help
Mark
Prindle 16 and Laguna 18DS
Ripon, WI
