I wanna make a bigger ice boat this year, if time allows it ?? I've tried steady pressure on the mast with weights using cinder blocks that I put into a small boat that I have... Here's the way I did it. I put the mast on the ground, then put some wood blocks under it at the ends so it was raised off the ground about a little more than 2'. I used a rope on the bow to suppened the front of the boat, I put the back of the boat on the mast, then I put the cin. blocks in the back of the boat so all the weight would be in one spot... I probably used about 5-6 blocks. Not sure how much it weighed, but it was alot. I left it like that for about 2 weeks... Still no change !
![icon_rolleyes](https://www.thebeachcats.com/modules/bbsmile/pnimages/smilies/icon_rolleyes.gif)
and other toys.......
Bernhards Bay. ~~~~~~
