Kenny, I think you will find the roller furling to be one of the best upgrades you can make, especially when launching/retrieving off dock or tight quarters.
First off, get hold of the Harken small boat Furler, (drum & swivel) Get the high load model, (435?) The only difference is the bearings, Torlon in the Hi Load. You can get it for $221, note the website will show a higher price, as that is the minimum LIST PRICE, when you add it to your cart the price will go down.
Here is one vendor, you may be able to get a local place to match it. Used ones go for around $150, so for a few bucks more you can get brand new.
http://www.defender.com/p…299748|750993&id=1015158
Now, the Prindle uses a different method to hoist the jib, but I don't see why you cannot use the same thing as the Nacra 5.7, or Andrews Mystere. Forget about the jib connections & S hooks at the top. Just change the forestay so that you have a pigtail at the top.
The forestay needs to be 5" shorter to allow for the furler, another 1 .5" for the tang, and another amount depending on how you decide to attach the stay to the drum, PTB, stay adjuster etc. You can cut your old stay, or get a new one & keep the old incase you decide to change boats & want to sell & keep the furler for your new boat. It is best to figure out how you will make all the connections, as that determines what type of ends you use. It sounds obvious, but a thimble at top & marine eye at bottom might work better than two thimbles. ie thimble as in the photo, or marine eye.
First a small tang attaches to the mast hound, then the upper swivel, then the thimble of the forestay. The bottom of the forestay can end several ways, before it connects to the drum. I eschew all the lower adjusters, & use 4' of V-12 Vectran to construct a Portuguese Turnbuckle, between the end of the forestay & a 1" ring on the top of the drum. This allows quite bit of room to play with mast rake, & I leave the shrouds as is, & haul on the PTB to tension rig. This is not my photo, but I use the same idea.
Now, hang a small block from the pigtail,(at top of forestay) Run your jib halyard around this block. Now, as you hoist the jib, you will zipper it around the forestay, & THE HALYARD. Get it, the halyard will also run inside the zipper, back down to the drum. Instead of tensioning the jib from the tack, you will tie the tack,(or use a small shackle) to the lower end of the shroud, or somewhere on the drum or PTB.
It will be tensioned by pulling on the halyard, then tying off at the drum or PTB. This will give a 2:1 purchase, which is fine if you are not a competitive racer, you are only pulling the wrinkles out of the jib. Now unhook the sister clip & stow.
I leave my boat mast up & jib furled (with a UV strip on jib) so I don't use a sister clip.
I didn't want to bother with tying/untying the halyard each time I tension the jib, so I threaded a small clam cleat to the PTB. I used a 21' piece of 3.8mm Spyder line (in bright lime green, cause it looks cool, & I remember Damon saying, never underestimate the cool factor
) as a halyard.
All I do is tension the rig via PTB, then pull on the halyard, slide the end into the clam cleat, & the jib is ready to be unfurled.
I have not had time to work up a proper album in the tech section. Send me an email addy via PM here, (so your email doesn't show up), & I'll send you a bunch of photos I took while converting mine, a few photos make much more sense than 3000 words.
There are a bunch of different ways to connect things, & your particular situation may determine what is the "best" way for your use. Many people would not bother with the clam cleat, I'm starting from a dock, & can barely reach the drum when standing in the water, & don't dare rig it on the lift, so I found the addition of the cleat to make life easier.
There are also some photos that I've gathered from other peoples setups in my members album NACRA 5.7, right next to yours. I think I stole one of Andrews that shows the top end fairly well.
The other thing that might happen is the jib sheet ends up being a bit to short. I just used a longer bit of line looped through the jib clew, & tied the ends to the jib blocks.
When you furl the jib, remember to wrap the furler line around the mast, or tie another piece of line through the clew & around the jib as a safety. If the wind is blowing & the furler line comes out of the cleat, the jib will unfurl & beat itself to death.
