Hello all. Just picked up a 1995 Nacra 5.5sl with a harken furler and have some questions regarding the setup. The PO only used it a few times and could not show me how to fix the jib onto the forestay and I have seen pictures of others setups here and it seems like mine may be missing something. I will try to poast a picture later but I have the cleat that is pinned to the furler and am trying to figure out how do I tie the extra rope off? Do I run it downthrough the pulley on the cleat and back up into the clew of the jib and then cleat it off? It sound slike the most logical thing to do as it would pull the cleat closer into the drum allowing it to be furled without the cleat catching the forestay but there is a ton of line left over and the line is actually smaller than 3/16 and am wondering if the jib halyard should be 3/16 instead of this really thin line. Sorry, hard to explain and will try to post a picture of it to see if I am missing something. Patrick Reagen has some good pictures of what it looks like mine should look like but I think I am missing something as there seems to be a lot of line left over after cleating it off and not sure what to do with it... Any help would be greatly appreciated as I am fairly new to sailing. Thanks.
jason
