That sounds strange since you had good results the first couple of times. Are you sure you put the plugs in the hulls (yes stupid question but it happens).
Hard to say where it comes from. 2" of water in each hull is A LOT! It the other times you were out it wasn't wavy it might be something simple up high on the hulls (say the tramp track or where the rigging goes into the hull). Some good speed will force quite a bit of water through a small hole, but like I said 2" through the entire hull is a lot of water.
Normally you would go around and seal all the rivet holes, along the tramp tracks and where the rigging tangs come through the hull using a good sealant (like 3M 4200 or some such). That sounds like it could be something more serious. It is probably worthwhile to do a leak test once you fix the hull that is split using some soapy water, a piece of garden hose and a hair dryer (or the blower of a vacuum).
Here are a couple of threads on it
http://www.thebeachcats.c…ms/viewtopic/topic/11764
Careful not to put much pressure into the hulls. It doesn't take a lot to crack them. What you are looking for are stress cracks in the hulls that could be allowing water in.
D.
