I have had this Nacra out a bunch of times now and it is tons of fun. I live inland here in East tennessee and winds are less than impressive most days. Today I went for a sail with my wife on the 5.2 and had a good time in some Reasonable winds. I got a couple questions...
We have to put the boat in at a typical concrete boat launch ramp. You know back your trailer down and then unload the boat and then park your vehicle and trailer, run to the boat and get it out on the water without pissing off everyone else waiting in line to put their boat in. Well this time luckily it is monday and most people are working so we did not have to worry about that. I am curious as to what you guys do in this situation. We got the tip to NOT take down the shrouds and trap lines just lower the mast and then coil everything up on the tramp and tie it down. We did this and packing up the boat went MUCH quicker so thanks for that. However, I still had to carefully raise the mast with my new trailer winch setup which is MUCH easier than before and my wife just cranks it up while I steady it until the shrouds come tight. I Usually put the jib and mainsail up but leave the mainsail unhooked from the boom so it does not blow the damn boat off the trailer. I leave the jib as loose as possible so it mostly just kinda flaps around a bit. Then we usually back down the trailer and TRY to control the boat in the water by hand until I can get the trailer out from under it and park it. This time we had quite a bit of wind and had trouble keeping it still while I parked the trailer and we managed to get it out of the longish channel between the boat dock piers and onto the end of the pier where we tied it off and then hooked the sails back up and sailed away. I am wondering do you guys usually raise your mainsail once out on the boat in the water or do you do it on the trailer like I have been? I realize this is a bit dangerous but we keep the boat strapped to the trailer and the main unhooked until we are ready to make off. What is the best way to do this? Do you guys use bumpers to keep the boat off the piers and safe from getting scratched up? I realize a lot of you guys put in on the beach but that has it's own issues....
We actually had a great day out on the lake today with good wind and nice weather. The other thing that is annoying me is that while this boat seems to go pretty fast for the amount of wind here I cannot seem to get it to float a hull? Today I seriously thought it was a done deal with the wind we had, it was supposed to be 8 knots constant gusting to 10 knots.... I know that is not exactly gale force but the boat sure seems to go pretty fast it just will not totally lift the hull....
I know I goofed up on something that may have caused the issue today and that is that when I repaired my rudder system after the rivets on the tie bar broke with new stainless steel fasteners I accidentally put the rudders on the wrong side of the boat and they have a slight dogleg in them that basically had them not pointing straight back rather a bit to the side. I am quite sure this slowed us down considerably but there was a few times that the wind really peaked and we ALMOST flew a hull. Do you think that the rudder issue would cause us to not be able to float a hull? I am always praying for nice weather and good wind for sailing on these lakes but it can be very tricky out there. You will be cruising along hauling butt pretty good and then absolutely nothing.... I am quite sure it has to do with the hills and mountains around here but it seems to never be consistent. I BOUGHT this boat so I could FLY a hull and I have yet to be able to.... This time we went when the kids were in school so there was a bit less weight on the boat just me and my wife so if it was gonna fly it should have today. I tried everything to get it trimmed out and played with the mast rotation and everything but no dice. Kinda frustrating really because with as much wind as was out there today I thought for sure it would fly... The jib looked great and the main was really pushing hard and the hull WANTED to fly a couple times. What kind of wind does it usually take for you guys to fly your hull?
Anyways, not whining here we had a great time and the boat really gets across that lake pretty good but I am wondering if I am doing something wrong here... peace
Pete
