Posted: Oct 25, 2011 - 11:31 AM
Hi flaco... well I used to run the 9/16 socket and take the tabs off... but now I'm using dyneema for my tramp, and the thing is so tight that as soon as I loosen one of those bolts the hull wants to cant in... such is the tension and stiffness of the boat right now. SO... I've left the tabs on for the last few sessions, including the shearwater regatta this past weekend (osyc.com)... lots of time on the wire. I wear booties or old sneakers, haven't had a problem. But I do wonder if one slips on the wire, that tab going into your ribs could make a real mess.
NOW, what I did with the pivot bolts/(studs actually) for the wings.. is I drilled and put a golf ball on each of them. I suppose w/a little work you could do the same with the tabs... inside the golf ball is elastic... so once you get it on there, the elastic expands and makes it stay on real well.. for humor's sake... I spray painted the golfballs blue... uh, it just matched the sails nicely.
final note... it "was" an SX boat, but I busted the comptip, needed a standard rig to sail in the hobie north americas, so put that on along w/stock hobie sails... then got a whirlwind pentex squaretop on it now, with whrilwind dacro job... and removed the wings.... am confident now single-handing... and it is a BLAST !! but... need to build a new soloRight in case of the inevitable.
Edited by robpatt on Oct 25, 2011 - 11:38 AM.
