Full length wetsuits are windproof, & warm, the thicker the warmer, but the thicker they are, the more restrictive they are.
Here is a guide for you.
http://360guide.info/wets…uit-guide.html?Itemid=58
http://360guide.info/wets…ure-chart.html?Itemid=19
Remember to use caution. What might be suitable gear for the 1st 10 days of sailing may prove inadequate should you flip the boat, & break something, resulting in being unable to right it & having to spend a couple hours in the water. Or, you rip a wetsuit open in an area of high heat loss, groin, armpits, sides of chest.
You guys have way better Coast Guard coverage than we do, all the same make sure responsible people know how long it will be til you contact them, then stick with your plan. Being stranded on a broken boat in the summer is normally just an inconvenience, once air/water cool down hypothermia is a killer.
I find many people are surprised at how "warm" it can be, & still suffer from advanced hypothermia. If you are lean & skinny, you will succumb quicker than the well padded guy. The majority of hypothermia fatalities are in temps well above freezing.
Many European sailors deal with cold water all year. A dry suit is best, but they are expensive, & less comfortable. I find that for myself,(skinny guy) a farmer John lower, & longsleeve upper is quite comfortable for several hours in 14C (57F) water, but only if it is a sunny day, with air around 16C-20C (60F-68F) Most wetsuits are a dark material, & a sunny day really helps. On those cooler days you will probably want neoprene booties as well, & gloves.
We have some pilots who go to the Carolinas every fall to windsurf & kiteboard. They love the shallow water/high wind conditions. With some proper gear you can easily extend your season. The price of wetsuits has come way way down, now that most are made in China. Ha.ve fun
Edited by Edchris177 on Oct 19, 2011 - 05:29 PM.
