rick white, who wrote the classic " catamaran racing for the 90's"sells a "hooter" kit for the hobie wave. people have also fitted similar furling hooters to the h14 and pics are available on the net. basically you need a special sail made for the boat and all up it's likely to cost us$1000 or more. if you want something off the shelf the only furling gennaker i know for small multis is the wetas and thats only about 8.5m2. personally i'm 1 of those who don7t think adding sail to the stock h16 is a good idea...
looks like you were getting hit with the "ajax timeout too"
for me it seems to mean the post has been sent even though it doesn't show for some time
the h18 should be better able to handle such a big foresail, do some research on the code zero "spinnaker" that the usa and dutch teams trialed for the beijing olympics
i think they used the standard tornado tube launcher but the sail was probably flat enough that it could have been furled
you can see from this pic how the halyard is much tighter/straighter than normal tornado spin, how flat the sail is and how they are able to use it upwind? when the other teams have kept there normal assym spins in the chute
