hi guys,
I have a Hobie Tiger and a friend gave me a spinaker in great condition but a litle bit different.More specifically,the foot is a little bigger( 4,25m instead of 3,75m of the hobie spin) and the leach is 10cm shorter but this doesn't bother much. I have problems on where to put the patches so the spi can fit in the snuffer. The snuffer is 2m(maximum from fully back where the patched stop up to the front edge).I know that i must measure 2m from the tack and the clew for the bottom patch bit in this spinaker it is not enough(the foot is 4,25m).I ve tried once this sail(that now has 2 patches on)and the head was out at about 0,5m(logically the top patch must be 2,5m from head) but clew and tack were in.how is that possible when the bottom patch is more that 2m from them?I ve also heard that the spi in the snuffer is not streched so i ll need less distance than 2m to put the patces...is that true?Any good ideas?Will I have to cut it in the end...??
