Line Size Length qty Color PPF Line Type
Barberhauler 1/4 16 1 white Red 0.55 Sta-Set
Batten Ties 3/32 2 8 White 0.3
Downhaul 1/4 15 1 blue 0.55 Sta-Set
Jib Clew Bridle 3/16 6 1 black 0.34 Sta-Set
Jib Halyard 5/32 22 2 Yellow 0.35 Excel Pro - Marlow
Jib Sheet 5/16 33 1 Red 0.67 Sta-Set
Main Halyard 3/16 26 1 White Blue 0.34 Sta-Set
Main Sheet 3/8 40 1 Red 1.69 Salsa
Rudder Down 3/16 4 2 Red 0.34 Sta-Set
Rudder Up 3/16 5 2 Blue 0.34 Sta-Set
Righting Line White Blue Old Main
Tramp Lacing Rear 3/16 11 1 Black Kit
Tramp Lacing Side 5/32 11 1 black Kit
Trapeze 1/4 3.5 4 Black 0.55 Sta-Set
Tarpeze Shock cord 1/4 0.46 Novatec
Traveler 5/16 10 1 Grey 1.21 Salsa
With some Christmas money and gift cards burning a hole in my pocket I started to work out my list of parts. The running rigging is the most confusing one for me since it's part science part art/experience. Since I've never had this boat on the water I'm running blind. I've done a bunch of searches which lead me to my current train of thought.
Both SLO and Salty Dog offer re-rig kits but SD only comes in white and I like the idea of being able to customize my colors for better organization. I'm not keeping with the traditional red/green layout for the mast for several reasons...mostly because there is no green on the boat nor does the jib halyard come down the mast.
Please let me know if you think this is off base. I'm new to cats and new-er to sailing.
Sta-Set is the industry workhorse and very cost effective and fine for many applications but am I over using it?
Halyards: Traditionally you want minimal stretch; but with the wire halyard notch for the main and the luff taking the tension on the jib its should be moot point? I assume there will be little to no tension on these lines while the sails are up?
Barberhauler/ Jib sheet/Clew Bridle: as a crusing sailor will Sta-Set be appropriate in these 3 applications?
Main / Traveler - Since I'm going to be handling these lines all the time and I'll be taking them with me when the sailing is done, I'm going for high tech and hand feel Salsa Braid. Ok mostly hand feel its a old non racing cat. Question here is 3/8 and 5/16 the best combo of sizes to go with? or should I go 3/16 all around? I want to be sure it will run freely through the blocks. I'm also debating a tapered splice between the 2 lines (different colors) or a double sheet bend
The rest of the lines are rudder up/dn and tramp lacing which I'm not overly worried about stretch.
The existing rigging was totally shot, rotten, faded and frayed I'm not going to reuse any of it except for the old main sheet which will be my Hawaiian righting system.
Thoughts?
Edited by bobcatnj on Dec 31, 2011 - 02:02 PM.
Bob Miller
1983 P16 Sail # 7312
Barnegat Bay NJ
