You should be able to lock down your rudders by simply pushing the tiller cross bar toward the stern (without really raising it) at each corner. There should be a discernible snap as each rudder cam locks onto the upper casting and holds it into place. Once in the locked down position, there should be virtually no fore/aft movement of the rudder. To manually release the rudders pull up on the cross bar to unlock them and pull forward to raise the rudders. The cams should rotate forward and not stay in the locked down position.
Once you have replaced any worn parts, it really is all in the adjustment. Of course don't forget proper lubrication. A properly adjusted and lubricated rudder system should function essentially like a new boat. A lot of guys that buy older boats don't realize this and think that a sloppy rudder system is just something they have to live with. Not so. The Hobie rudder system is simple and well designed. In my opinion, it is one of the best on any beach cat.
For what it's worth. a lot of rudder system parts are interchangeable between the H14 and H16. This includes both the upper and lower castings and the rudders themselves. You can always check the parts catalog to be sure. Beginning in 1983, I believe. both the 14 and 16 came with adjustable upper castings whereas the earlier ones did not. So, if yours is an older one you might want to consider swapping them out. There are lots of used parts out there for these boats. There is a guy who advertises used Hobie parts right here on thebeachcats.com classified.
There is a lot of information on the web regarding Hobie rudder systems. Here are a few articles to help get you started.
http://www.hobiecat.com/s…t/tech/rudders_cams.html
http://home.earthlink.net…hives/v1-i8/feature2.htm
http://www.thebeachcats.c…hives/v1-i7/feature1.htm
Enjoy your 14. I still have a 14 turbo in my fleet. It is a fun boat to sail in the surf.
Edited by DaveW70 on Jan 01, 2012 - 10:30 AM.
Dave Wilson
Hobie 16, Hobie 14
Tampa, FL
