Actually, I did something really similar to this when adding speakers to my 5.2.
I agree, you'll want a flat port, (or marine speaker =), not the curved one. I'm going to tweak the rest though..
Take a 1 or 2 gallon plastic flower pot, and cut the bottom off. Cut one side all the way down, too, so you can roll it like a scroll.
Put the rolled up flower pot into the hole you've cut* for the inspection port, and let it expand.
Make up some thick fairing compound and slather it all over the edge of the hole. It's easy enough to sand down that too much isn't an issue, as long as you don't make it so thick that it heats up. It took me about 3 layers of fairing compound when it was said an done...I'd just do two at first though. After you've got two layers on, and a decent purple build up, and it's all dried and cured (24hours-ish for the 2nd layer) pop the flower pot away from it and pull it out.
Grab a
durablock and 60 grit and start shaping. It'll take less than 15 minutes. You'll quickly see if you need to add some fairing compound to get a flat smooth surface.
After it's fair, clean it up and add gel coat preval sprayer...or your choice of topcoat. I'm terrible with gelcoat so I can't help you much there.
Mark your holes, drill, and pop rivets.
*If your hole is too large for the port I'd think about getting a larger port. Otherwise you're adding a layer of glass and there's almost no reason not to just fill the hole/whole thing. If the hole is too small, you can lay the port on a piece of wood, cut out the center, then use the wood for a jig on the hull (as you can use the 6 holes in the port to fasten the wood to the hull)
Rob
OKC
Pile of Nacra parts..
