I was under the impression that all the Prindle 16-19 rudder systems were all the same, it appears there is a difference in the blades. The early 19 blade is a bit shorter, the bottom is 90 degree to the trailing edge. Anyone ever run across this.
Edited by johno3300 on Mar 21, 2012 - 08:37 AM.
See you on the water
2003 Bimare 18HT solo Sailor
Formerly P-19MX solo sailor
Portsmouth RI
