A Prindle rudder casting has an upper limit built in that stops the rudder pin.
About what make of cat are you talking?
-- Sheet In!
Arizona, USA --
On the H14, the rudder pins interfere with drain plug removal and replacement. It's pretty much been that way forever. I use hairpin cotter pins on the bottom of the rudder pins so that I can slide them up out of the way when I need to remove the drain plugs.
