Hello,
Since this is my first post, I'll introduce myself here with a few questions. If this thread would be more appropriate under Technical Help, I'll move over there for further discussion.
I would like some advice and input on an early G-Cat project (3 digit sail number). PO dismantled boat about 7 years ago for refit/rebuild which was never completed. Other than the hulls still attached to the crossbeams, all other pieces available are unmarked and loose.
Both rudders had ‘snapped’ in half and I was told this occurred while sailing. However, the port rudder mount is cracked at an old weld repair.
Do G-Cat rudders break that easily while sailing? Is this a common trait of G-Cats or would some type of non-sailing accident had to have happened to the boat?
The rudders feel extremely light weight to me, but I have no experience with them so I do not know how heavy they should feel .
Damon has been kind enough to send the G-Cat Rigging Manual to me as a pdf file. Once I can have it printed larger, I should be able to read the small text and noted drawings to identify the pieces that are supplied with the boat.
Thanks fellow G-Cat owners!
I’m looking forward to hearing from you,
AJ
Edited by BadKitty on Mar 27, 2012 - 08:46 PM.
AJ
Barefoot 12 Proa Outrigger
Coastal NC, USA
