Hi,
The trailer that came with my Pacific Cat was fabricated by the previous owner. It's built like a tank out of 1/4" wall 3" steel tubing and U-channel. But the original paint job left a lot to be desired. At this point I could best describe its color as "rust and paint calico". (Fitting for a cat, actually...)
This trailer will be used in and around salt water. I took a look at the ramp I'm likely to use, and there's not much chance of keeping this thing dry. Right now my plan is to:
- Strip all remaining paint (not that big a task)
- Wire brush the whole thing to get rid of loose rust
- Treat the whole thing with Ospho (the previous owner gave me a gallon of the stuff with the boat)
- Paint it
So that last step is the $64 question. What would you paint an ungalvanized steel trailer with after treating it with Ospho? Right now I'm kinda leaning toward a good primer coat and Rustoleum. (If you find yourself laughing uproariously at this and thinking "What a clueless @#$%!", be kind and let me know.) Any other choices I should consider?
For what it's worth I don't have a facility for spraying, so this will be roll and tip (or just roll... it's a rusted trailer, after all).
Tom Benedict
Island of Hawaii
