You have the newer style cam cleats, the bungee/shock cord is attached car to car, with just enough tension to keep them pulled towards each other, in other words the default setting is close in to mast. When traveling broad reach or down wind, pulling on the jib car line will haul car away from mast out to side rail, almost acting like a barberhauler, you have the advantage of being able to change jib settings for each point of sail. I cant see your jib blocks but here is a pic from Tech Gallery, has the older style jib blocks with the spring loaded pin to set the blocks on the traveler
TurboHobo
H14T
P18
P16
