So when making sure that my simple fix was in deed simple....I delaminated from 2 feet from the crossbar forward to darn near the point of the bow. I gave it a push with my palm and crunch and I kept pushing around to see the extent of the soft spot....It wasn't there in the fall when i got the boat but glad I found it now and not after paint or while on the water.
Not the way I wanted to spend my day off. At this point I had nothing to loose so I went drill and fill and will sail to fail.
It came out rock solid minus the glass on glass laminate sections at the far front rear and sides.
My question is; the areas that are 2 layers of fiberglass and no foam I didn't see a way to inject those areas and they are a bit soft but are often only 2' until they meet the end of the hull or side.
Bob Miller
1983 P16 Sail # 7312
Barnegat Bay NJ
Find more Prindles on Facebook
https://www.facebook.com/groups/173120656090532/--
