H17 with wings vs. no wings
I recently picked up an old H17, but the seller did not have the wings for it. Additionally, all of the tubes need to be repaired. 2-3 tubes are in such bad shape, that a repair would look a lot more like a complete rebuild. Considering this, along with not having the wings, I'm thinking of just getting rid of the tubes completely. I'm not looking for technical help, I just want to hear any opinions on what you think about a H17 without wings. Would it really take away from the boat, sailing-wise, re-sell value-wise? Would it help in any way? Any thoughts?
Jake
H17
put a jib or spin on so you can trap out more often and just enjoy it... if you're not trapping it's going to be a low, low wet ride... which is ok, but trapping more fun icon_lol
Same issue here.. I have 2 17's One is OK in the wing dept.. I got"never repaired " 17 with wings but 2 tubes are toast.. Hobie makes a plug to keep the water out.. I will do a pix if you like.. Have not sailed eaither one so let me know what you find out.. Going to sail the one with wings soon. News at 11 from me. Cheeers Hal
Hal Liske
Livermore CA
It's a Sickness
I Need a A Cat Please
I personally like the wings. They add a lot of comfort to sailing, especially in light air. If you trap, there is little difference, but you can trap from the wings to increase the leverage. In fact, I would not buy another cat without wings.
If I were you, I would shop around for used wings. New would cost you as much as you boat is worth. For semi-permanent solution, you can get plugs at
http://www.murrays.com/
50-50690001 WING SOCKET PLUG H17 (SET 4) $19.95
I you never tried the wings, you may even be happy with your wingless and plugged boat.
Jack B
Hobie 17
BC, Canada
Lucky Me.. I have a set of wings with both boats. Not sure I want to do the repair. Perhaps sell the one boat wing-less and sell the wings seperatly.. (and not have to mess witht he repair. Cheers Hal
Hal Liske
Livermore CA
It's a Sickness
I've done tube repair last fall and it was not too bad. You will need to install access ports.
Jack B
Hobie 17
BC, Canada
Got Pix?? I have seen the one from the hotline.. Bee nice to get one from one other method.. Hal
Hal Liske
Livermore CA
It's a Sickness
More on wing pocket repair
http://www.hobiecat.com/f…81a3ff0ba65d2fa7090ccbb6
Jack B
Hobie 17
BC, Canada
Hal if your keeping them on the beach somewhere and not moving them around you can just seal them in for teh season with some good silicone. If you plan to trailer them much then this may not be good. What kind of shape are your sails in? Mine were not very good.
The plugs from Murrays are intended for keeping moisture out in the winter I think not for sealing the tube while sailing.
