There is quite the buzz recently about people making cradles from PVC pipe or fiberglass, molding them to the hulls and padding them with carpet.
There are also lots of older posts about snug cradles with carpeting retaining water and causing blisters in the fiberglass hull.
Those of us that have found blisters in this situation, what did you do about the cradles- cover with something else/use not-so-snug ones/other alternatives? Do you think the heat where you live is a factor in this situation?
Is there a better material for lining the cradles that does not retain water and has less friction than carpet? I have cat skids that I use on rocky shores that are made from large (white) PVC pipe. When I run the hulls up on them, its the PVC that wears off- not the fiberglass. I'm tempted to simply sand the unlined PVC cradles smooth, round the edges, drill holes or cut grooves to ensure drainage, and let them wear like the skids.
I plan to put cradles on the trailer front crossbar and dual rollers on the rear. There is no mast or rudder weight on the rear of the cat ever, so the rear rollers will allow easier loading onto the trailer and improve sharing the stress from the current single roller.
All comments are appreciated.
It's Spring- Sheet In!
