Posted: Apr 27, 2012 - 07:34 AM
i have used 4mm vectran or dyneema instead of the wire for years now.. no problems .... ($10 of line) I changed this to help save my gf's shins, but the line gets almost as tight as the wire did... so it didnt do much in that respect - should be noted that you will never get line as tight as a wire, so your blocks will "sit" higher off the deck .. this actually has a benifit of reducing the stress on your tramp track (at least thats where my 4-way jib system attaches)
blocks on the wire / line aren't even really needed (a shackle will run fine) - removed mine years ago
shock cord for returning (inboard) also is not needed ... if you move your jib outhaul and move it inward (for upwind / better pointing) you will need to adjust your sheet (most likely need to release it before you can move the blocks inboard), and as you sheet your jib sheet,,, your jib blocks will move inboard ...
IMHO - less hardware saves weight, money, less gear to break
Edited by MN3 on Apr 27, 2012 - 07:36 AM.
