There are two other forum threads here having to do with mast base replacements, but I didn't want to hijack those. So, I am replacing my NACRA5.2 base and dolphin rod with the group of parts I bought from Murrays. Thanks to those for the guidance in removing the rivets to get the old mast base out. Now I've got two new issues.
Issue 1. The new rod is more than an inch longer than the old one: Am I to cut this new rod down in length to match the old one? Or is my mast just going to sit an inch+ higher than before?
Issue 2. The new mast base leaves sizeable holes in the bottom of the mast. This was fully covered by the old mast base. Is this going to be an issue? It's at the bottom, so water should really get in there much, but if I end up turtled, isn't this going to let a lot of water down into my mast?
Sailing in DFW area, TX
NACRA 5.2
