Southern CA Racing
Happy Memorial Day and welcome to the start of summer… Damm these have been a fast few months.
With this I do want to make a shameless plug for a few races we have coming of the coast of Ventura.. Maybe we can get some more racers this year!
Race #1 Frenchy’s Rum Run, June 30th, 2012.
This starts at the Mandalay bouy, runs out to Frenchy’s cove @ Anacapa Island and back to Ventura Harbor. This is not that technical of a race and the winds usually line up for a beam reach out and a screaming beam reach in.
There will be no chase boat, nor will there be a tow boat out to the start line.. The winds usually starts to build around 10:00 is so any competent sailor should have enough time make the start line..
Here is the website for the race - http://venturasailingclub.org/calendar/
Race #2 The Milt IngramTrophy Race, July 14, 2012.
Again starting near the Mandalay buoy, the race proceeds to Platform Grace and then Anacapa Island, leaving them to port. It then leaves the Ventura Harbor Whistle Buoy to starboard, and finishes in the Ventura Harbor entrance channel. Got a spinnaker, this is your race.
PBYC will provide a chase boat for this race and will need at least five beachcats entered to make a class.
Here is the NOR http://www.pbyc.org/RACING/2012_IS%20NOR.pdf and here is the entry form http://www.pbyc.org/RACIN…12_IS%20Entry%20Form.pdf
Race #3 Tri-point Ocean Race, August 18, 2012.
Again this race starts at the Mandalay Buoy offshore from the Mandalay Power Plant, proceeds around Platform Gina then Anacapa Island, leaving them to starboard, and finishes in the Ventura Harbor entrance channel. The handicap distance is 34 nm.
THIS IS A FULL ON BEACHCAT RACE, and usually bring a few cat sailing legends out of hiding. If you’re planning on any of them this is the one to do, but I do encourage that you sign up for all three..
Again Here is the NOR http://www.pbyc.org/RACING/2012_IS%20NOR.pdf and here is the entry form http://www.pbyc.org/RACIN…12_IS%20Entry%20Form.pdf
And a note, I am currently boat-less and may be available to crew for the Tri-Point depending on how the little hip procedure goes in a few weeks.
Edited by JohnES on May 29, 2012 - 09:50 AM.
John Schwartz
Ventura, CA
John, thanks for posting this.
You're catless??? You sold the I20?
I was looking forward to seeing you on that beast.
John,
Please add these events to the calendar so they don't get lost, there is an "add event" link under the Calendar tab at the top of the page.
Damon
John,
Frenchy's is already in there.
Anybody that has an event details can add the event to the calendar, doesn't have to be the official source, just try to make sure you have important info like the dates and contact info correct.
klozhaldJohn,
Yes, but it has the wrong contact info...
John Schwartz
Ventura, CA
