I know the topic of mast rake / weather helm has been beat to death but I have a specific question, and nothing to compare it to. My previous dinghy was set up wrong and I didn't have the knowledge to know it or fix it.
Right now I'm not running a ton of rake (maybe 3-4 holes down from the top) and I have the rudders set up as the manual calls for (1/2 inch aft of the transom i think). when I'm sailing to weather there is hardly any load on the tiller until the wind gets above 10knts or so. So she will turn into the wind if I fall off. When I tack I can throw the tiller over and then "gracefully" switch sides and the ruder holds it course for a second or to while I switch hands. Same goes for if I need to go hand over to hand pull in the main I can let go of the tiller for a sec and maintain course.
Is this normal or should I be sailing with a bit more rake/weather helm or did I stumble into a really balanced set up?
Bob Miller
1983 P16 Sail # 7312
Barnegat Bay NJ
