I started doing a delam repair on my P16 decks and found a couple areas where my drill bit was going right through the inner layer of glass. It's not because I wasn't stopping the drill in time, because as soon as I went through the outer fiberglass there was nothing inside. It's as though the inner layer was cracked or split. The deck doesn't appear to have been repaired before but maybe it has. Has anyone run into this before? Is this a sign of more serious internal deterioration? The odd thing is that last summer the decks were solid except for one small soft spot and this spring, the whole front deck is delaminated an there are a couple other spots on the other hull. Perhaps from freezing during winter?
Jason Kasper
2000 Mystère 5.0XL
Lancaster, Ontario, Canada
