I bought a used one of these today: http://www.boatrailer.com/images/HPIM0233W.JPG
The previous owner had taken off the rollers and cradles, and moved the axle very far forward on the frame (for an A cat).
I have a Nacra 5.8 to place on the trailer, and would like some input on proper trailer balance, and can't seem to find a thread on this topic (if there is one, please point me toward it). His recommendation was generally to keep the forward beam above the axle, and not exceed the tongue weight (is this possible on a 650 lbs cat?) I've read in other posts that this is where the center of balance is when rigged. Could I get some recommendations for :
-locating the axle on the frame
-vertical distance for the rollers and cradles above the ground (these are adjustable by about 5")
-and placement of the cat on the trailer assuming I'll be winching the mast up and launching on a very flat concrete boat ramp?
He had also placed the front cradles on top of two 2" blocks, but I'm assuming I'll need to remove one or both of them, as it looks like it would place the boat at too high an incline even with the rollers extended as high as they will go. The Nacra's hulls are so tall around the cradle point, is there any benefit to having the boat inclined at such an angle on the trailer?
JR
